I see online that the mc4000 is compatible with ios.
How do I set it up? I don’t think it’s plug and play.
Although I don’t have direct experience with connecting the Denon MC4000, it should be just plug and play…If you are using an iPad, then you will need the official Apple Lightning to USB 3 Camera Adapter.
Another thing to note that you should be able to Midi map your controller to suit as well using the Midi learn function.
I did this on my Rane One controller.
I have been able to Midi map extra features like Neural Mix to various knobs and buttons when using the Shift key function…
So a regular usb c adapter won’t work?
I can’t say for sure but the Apple Lightning to USB 3 Camera adapter allows you to charge your iPad whilst using the app…
A few people have reported not having much success with using cheaper knock off cables and adapters…
I use the genuine one and it works fine…
I’m actually going to pick up another one as a spare to have as a back should it fail at the worst time, ie during a gig…
The USB-A to USB-B cable connects between your controller and the Apple USB 3 Camera Adapter via the USB-B port, then your regular USB to Lightning adapter connects from the Apple USB 3 Camera Adapter to a USB power brick…
The best way however is to use a 30 Watt USB-C charger and USB-C to Lightning cable
That’s how my set up is as the regular 12watt power brick couldn’t keep up charging my iPad after a few hours…
Hi there
Maurizio was assuming that you had an IPad with a lightning socket on it which used to cause a lot of issues with non apple usb adapters.
You however said you have usb c, so you should be fine with a generic usb c hub.
You can also test the system with a usb b to usb c cable, but as Maurizio says, it won’t then charge your iPad (fine for home, not too great live )
I used an apple adapter when I had an older iPad with lightning and used a hyperdrive hub when I got the iPad Pro with usb c. The issue with those is that you still need another usb charger + cable to plug into them to charge the iPad, big spaghetti mess.
I now have the ADG usb c hub/100w charger in one device, which cuts down on the cables and also lets you plug in a hard drive/keyboard/mouse/memory card etc & charge your iPhone all at the same time.
Plenty of options out there.
Awesome. Thanks so much!
