How to use Kingston wi drive with djay or vjay ?
Is it possible to do that or there is any plan to do that in the near future?
Hi Omar,
djay for iPad and vjay can only access the device’s local media library.
Though, you can try djay for iPad’s new “Open In…” feature to load songs from other apps (e.g. Dropbox or other file browsing apps which also support “Open In…”).
Thanks.
So, Algoriddim-- what are the plans to to integrate this functionality into djay? I have more music can can be stored on even the largest capacity iPad, and the Wi-Drive is the only way to carry it with me to use with the iPad.
and about MobileLite Wireless
