Hi I’m just wondering how to use my stems on ddj rev 1 with djay pro like I want to be able to isolate vocals, drums and stuff using my sampler pads as I am using a macbook and can’t seem to find the way to enable it
MIDI Map the REV 1 from the MIDI menu. In the example below, the REV1 will show up where it says “No MIDI devices found”.
Press the pad/button you want to map and assign it to a Deck.
Select a Neural Mix command from the list.
Thanks for the detailed explanation @Michael_Wisniewski!
Hi @Arya2302, welcome to the Community! Please confirm if Michael’s post answered your question or if you have any follow up questions. Thanks!
