Hi all
First time using the app, usually use Serato/RB/VDJ so know my way around a bit. I’m trying to use tempo blend. One track 124 and the other 85.5. I have enabled sync and temp blend in the settings as per pic. When I go to mix using the cross fade nothing happens, the 124 track goes to 85.5 and just stays there once fully slided in? Do I need to activate tempo blend? i have searched and all I can find is someone clicking omn the ‘blue line’ which I can’t see on the GUI - The only video I can find is on the algoriddim site and it’s using an iPad so can’t see settings.
I’m using DDJ-SR2 controller.
Thanks in advance.
Rik
