Version 3.1.5 For Mac OS
Hi everyone,
I only use MP3 Finder for djing.
All my mp3 have been rename. Is it possible to use the name I chose ?
Hi everyone,
Hi @Neids,
Thanks for joining our Community.
Itās not currently possible to edit tracks metadata directly in djay, this has been previously discussed here:
For now, in order to edit the data of your mp3, youāll need to use a standard ID3-Tag editor.
Cheers, G
Thank you for your answer but you didnāt understand what I asked.
I precisely donāt want to use the title written in metadata. But instead I want to use the name I attributed by the Renaming function.
Hope you would help me as soon as possible.
I donāt think I understand what you mean by āthe Renaming functionā. The Finder section of the djay library should display the name of your files. Make sure to refresh the library (ā+R) if youāve just edited something.
OK. Iāve got a MacBook Pro. Letās choose a MP3. The name is ātake on meā. I rename in āAHA take on me 1985ā. If I use MIXXX or DJUCED Iāve got the name I edited āAHA take on me 1985ā. If I use DJAYproAI, itās using the title in metadata āTake on meā.
By now, MIXXX doesnāt work with my Hercules impulse.
With DJUCED I can use the title (metadata) and/or the name of the MP3. unfornatly I hate HOTCUE function.
With DJAY it seems I can only use the Title. That is insane.
Why would you store so much information into the file name as djaypro supports several metadata fields already?
Hey @Neids,
@dj_romy_fi has a point, on djay PRO AI you can display a lot of metadata information in your library. Here is a look at the Finder library in djay PRO AI, you can open this by right-clicking on the column headers:
I believe this is because djay is still looking at ID3 Tag for the name of the track. Does this appear this way in the library and when you have the track loaded on the decks?
Try changing the ID3 Tags of your tracks with any ID3-Tag Editor that would be a way to solve the problem.
Cheers, G
