Hudl2 Lollipop 5.1 Djay 2 hanging
Hi heplers,
I have a Hudl2 running Lollipop 5.1
Have reset the Hudl to factory settings twice, relaunched the OS, re-installed DJay 2 more than twice.
Still, DJay 2 hangs when loading a track.
Other functions of the app work as they should.
When loading a track from any source DJay 2 hangs?
Prior to OS Lollipop (Kat Kat) Djay worked fine…have I missed something or are there others in the same situation?
Would appreciate any help with this problem :slight_smile:
Thanks in anticipation.
Hi Byard,
thank you for pointing that out, could you please contact us via support@algoriddim.com, that would be great.
Thank you in advance.
