I can't access the library - Chromebook
  • Device model (e.g. 2020 iPad Air 4th Gen): ip Slim 3 Chromebook
  • Version of operating system (e.g. macOS 14.4.1): \ chrome os version 132.0.6834.62
  • Version of djay (e.g. 5.1.2): newest
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): n/a
Your question:
I don’t know if I’m just confused or dumb or what but I can’t seem to be able to access my library by pressing tap to load and the music note button just gives me a track settings menu that looks like this which i’ve not seen come up before
help i’m stuck
thanks in advance
Hi @notlenor, it sounds like you are doing a long press on the musical note instead of a short press. Alternatively, you could try switching from Classic Mode to Pro Mode and enabling the Library View.
