There is no where accessible to press apart from TRY IT FREE.
I don’t want to press TRY IT FREE, I want to use the app which I can’t now access.
If I close the app it doesn’t remove the splash screen. If I reboot the iPad it doesn’t remove the splash screen.
Please advise?
If you have paid for it try ‘restoring your purchase’ if you haven’t purchased then you will keep getting this message until you try for free I think for 7 days.
You cant tap anywhere else on the screen apart from TRY IT FOR FREE.
Have you purchased Djay Pro, either on monthly or yearly plan?
