I’m using a I Dj pro with iPad 8th generation.
And job wheels are working sometimes and mostly not. Is there a fix for this.? All apps are updated and the latest software
Hello @Mark_Tucker ,
Thank you for posting this in the Algoriddim Community.
First, it’d be great if you could double-check that your controller is working properly. To do so, you can follow these steps:
- Download the App Midi Monitor
- Connect your Numark iDJ Pro and launch Midi Monitor
- Move the Jog Wheels and see if Midi Monitor responds to it
Please us know how you get on and if the controller responds. Cheers!
