I do not get Pre Quing to work with my VCI 400. With Traktor S5 it works.
Please can you help me?
Djay settings are correct (With Traktor S5 it works)
Cue/Master is in the middle position
Level is in the mille position
PFL is on
I found the issue. It works now.
I used Virtual DJ 8, Flow 8, Traktor Pro 2, Mixed in Key. First I thought Traktor Pro 2 Traktor S5 and Apple Music are the best products on the Market.
I was wrong
as longer I use DJay Pro as more I like it. I bought Traktor S5 3 months ago. The Traktor Pro 2 is a heavy bulky Dinosour Software compared to DJay Pro. Also Spotify is better then Apple Music.
My controler VCI 400 does not send MIDI when I turn the Monitor Volume Knob.
If I use a other knop for Monitor Volume it works.
It looks like that Traktor default Monitor Volume is 100% and DJay Pro default Volume is 0 %.
With Traktor it works
thank you very much for your post.
Could you send check if your djay sound Device and Pre Cueing settings are correct?
You can find the Pre Cueing settings by clicking on the little Headphone button in the top left corner.
Thank you for the reply and your nice feedback.
We are glad to hear that things are working as expected.
