I have a few Questions
Questions
The first question I have is it possible to set up Djay Ai so that bpm default will be
from the slowest bpm to the fastest bpm? Without every time opening the software
and manually having to chancing it?
The next question I have is it possible to cut a short cut so you can change
crossfader curve from default to cut, without having to the menu’s to do it.
