I purchased DJ Cable by griffin and would like to know if it will work with DJay Pro 2 on my iMac, and how to hook it up and use
Hi Greg,
as Stephen thorpe said, you don’t need the DJ Connect for pre cueing.
After connecting the Griffin DJ Cable to your iMac headphone jack, open the djay Pro Preferences and select…
Devices > Pre Cueing > Split Output
Now you can use your splitter cable with your iMac.
Cheers,Lukas E.
yes it works perfectly :slight_smile:
Do I have to purchase DJ Connect as well???
No
Is this possible with Djay Pro 1?
I cant get a clean cue audio signal. The mix is always in the pre-cuing signal. I use the exact same settings in Djay Pro 1 (1.4.5) and Djay Pro 2. It works perfectly in Djay Pro 2.
