I purchased the the Djay Pro and a Denon MC 4000, was in the basement and the Automix stated it wouldn;t work on Automix in the external set up…
I hope this isn’t the case…
Hi bradley,
unfortunately while in the external mixer mode Automix is not supported.
Can you tell us why you are using the controller in that mode, maybe we can find a work around?
Cheers,Lukas E.
Have you tried using the Denon in midi mode? If you do so the Automix is working flawlessly.
Hi Bradley,
after connecting the controller to djay a midi mapping pop up window should be displayed, accept the mapping and you should be fine
Thank you for the email, i was using it when we had people over for bbq and use in the back yard.
BK
Hey Lukas,
Maybe I am missing something
How do you use it in midi mode?
I plug in my Mac with djay pro and then what??
Bk
