IAA (Inter App Audio) support in djay on iOS
For those that use AUM (or other any iOS daw) it would be so nice to have djay show up as an IAA from inside of AUM. That way you can set it up on a channel and add synths, beats, effects on other channels and route the output however you like.
I mean, AUV3 is great but having djay as IAA would get the job done!
Unfortunately:
deprecated 3 major iOS ago, but maybe iOS17 has a few tricks up its sleeve…
HOWEVER - if you’re a Macbook person: BlackHole: Route Audio Between Apps
follow on their discord - they’ve been working on a replacement/upgrade package called Dipper for those running Ventura. It’s in alpha
