I have an iPad3 and Numark iDJ Pro controller using dJay2. When I have a tune playing on the inactive deck, if I cue that record it lowers the sound from the active deck. This is really bad for playing live. Is there a fix? I have looked through loads of other threads, from years ago, but never seen a solution - please help!
Hi James,
thank you for your post and we are sorry to hear about your problem.
Can you tell us a bit more about your setup, how are you connecting your speakers to the iDJ Pro?
Cheers,Lukas E.
Hi Lukas,
thanks for getting back to me!
I simply use the phono sockets at the back (red and white sockets), and link that to my amp phono sockets. When I play out I use phono to XLR and plug the XLR leads into the power amp of my 2K system.
This is the same set-up I have always used and has worked perfectly well in the past. The only difference now is iOS and the app have both been updated to the latest version.
James
