idj pro low volume when effects are active
I’m Super Happy With My New Idj Pro, Especially After The Very Welcomed Last Update.
My Only Concern Now Is The Fact That When I Use The Hardware Effect (Not The Xy On The IPad), The Master Volume Drops, This Is Quite Annoying.
Any Suggestions?
Many Thanks.
Leroy.
I’ll try to reproduce this issue and get back to you.
Same here. After initiating “delay” for example via “effects” tab on unit, I find the track with the applied effect is lowered well below what it originally was… Please help.
