Id Like to know the shortcuts on the app when using iDJ Pro, such as when you swipe the platter in reverse it causes a reverse sound on the track youre playing…stuff like that. I know on the idj live you could press that “power” button on the actual screen to cause the song to slowly stop like it was a real turntable. is it possible to do that when its connected to the idj pro?
I was looking for that too, Enrique. You can try to adjust the STOP DELAY in the General section to 2 to 5 seconds to give you the power off effect. That’s the best solution that I tried.
