Hi there I recently changed the start/stop/reverse button to brake at 2 secs and now my left deck on the hardware is playing faster than the right even when synced anyone know what’s wrong? Cheers.
Hi Alexander,
Thank you for contacting us.
The start/stop delay setting should have no effect on the syncing.
* Which djay version do you have? Please tap the gear icon and scroll down to determine the version number.
* Does this happen with all your songs?
Does this also happen when the iDJ Pro is not connected at all?
Hi there
Thanks for replying I have version 2.6.1 on the ipad 3. The left deck on the hardware and on the ipad itself does it. Hope you can help.
Alex
Sorry I meant to say it happens with all songs.
Yeh just checked both tracks at 150 bpm and still out.
Is there a reset for Algoriddim? Maybe that’s my fix!
Thanks.
