Idjay Pro Bleeding Fader
The cross-fader on my Idjay Pro is bleeding. Are they contact or optical faders. I was hoping optical. Either way, solutions are welcome. Thanks!
Hi Kc,
Which iOS version do you have on your iPad? Did you perform the firmware upgrade on the iDJ Pro?
Hi Edward,
please note that the post is over 3 years old.
Could you tell us which djay version and iOS version you are using?
Thank you in advance.
I am looking for a solution for this as well, any luck?
Hi I used the traditional fader spray (electronic contact cleaner) and it worked…no more bleeding for now!
