Hello
As i easily do on the iOS Djay version, i’d like to import Beatport playlist with the Mac version of Djay but i fail to find the way to do this… could someone help me please ? (i just cannot find the arrow menu like the iOS version…)
Regards
Hello
Regards
Hi @JiPenade,
Have you already tried importing your Beatport playlists using the TuneMyMusic transfer tool found at the link below?
https://www.algoriddim.com/streaming-migration/beatport
Looking forward to hearing from you!
Hi
My goal is to import my playlisys easily from beatport to djay. On ipad it s easy : you just click on your beatport playlist then import. But on mac i cannot find this button/feature….
Do i miss something ?
Regards
My second goal is to manage my imported beatport playlists into djay : add and remove tracks, move them, etc,…
solved by Algoriddim support :
-first create a djay playlist
-go to the beatport (or tidal) playlist
-select all tracks
-drag and drop them to the djay playlist
not easy but it works
Regards
