Please also consider sharing a short video or screenshots to help clarify your suggestion
YOUR SUGGESTION:
I hope this suggestion is no duplicate, but I couldn’t find any related suggestion.
My suggestion is quite simple. The same way, you can export playlists, it would be great when you could import the same format.
This would allow sharing or changing playlists with other tools, apps or persons.
If this is a duplicate then please close this thread and refer to the original suggestion.
Hi @djay55555 , thanks for the suggestion! I’ll share this with the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Hi again @djay55555 , are you familiar with or new OneLibrary feature? I think this might meet your needs. Please check it out and let me know.
macOS:
Take your music anywhere with OneLibrary. OneLibrary lets you create a portable djay library that works seamlessly across devices and platforms. This allows you to take your djay music collection, playlists, and library data with you and use them...
Windows:
