Import MIDI Mapping from Different MIDI Device
Hello everyone, so allow me to explain my situation
I uses TouchOsc vie bluetooth midi to control djay, I’ve made a mapping for it and now I wanna create a backup incase something happens and I need to connect via cable
but somehow. via cable and via bluetooth my iPad shows as different devices, my question is
can I import my already made iPad Via Bluetooth mapping to my cable connected iPad bluetooth mapping, if can, how?
thank you
Hi @echa0361, I’m not 100% sure as I don’t personally use MIDI bluetooth connection. However, I see no reason why the same mapping wouldn’t work.
For more on sharing your MIDI mappings on macOS, please refer to the linked topic below from the macOS user manual:
What i mean is i want to load a mapping made with my ipad bluetooth, into my cabled setup
Because when i use wireless and cabled, my ipad is recognized as a different device, wirelss my ipad is recognize as Echa Ipad Bletooth , and when i use cable its recogmize as Echa’s Ipad and i get a blank midi mapping page
I can remap it button by button, but on my wirless ive extensively mapped my ipad, i wanna know if its possible to import my Echa Ipad Bluettoth mappong, to my Echa’s Ipad Mapping
Thank you
Ah, I see what you mean @echa0361. Thanks for clarifying. In this case, you will need to create a new mapping if djay sees it as a different device.
Okay, thanks for the clear up, ill re map those again
You’re welcome @echa0361
