Import MIDI Mapping in djay Pro for Windows 10
Hello,
I read some messages on forums from djay Pro users in Windows who cannot find how to import a djay pro MIDI mapping in Windows 10.
Importing in djay pro 2 for Mac is simple and stable, but apparently no in Windows.
Is there a stable process to import a MIDI mapping file (coming from DJTechTools website) in Windows 10?
To help I need information
  1. exact name of the MIDI mapping file
  2. exact name of the controller name shown via “MIDI settings” -> Devices
Thomas
I have the same problem.
I bought and downloaded Djay Pro from the Windows 10 store but since it is from the Windowds appstore, it doesn’t have a folder for it’s own. Only the app.
I found a MIDI mapping folder for my Hercules P32 after trying to configuring and setting up all the buttons manually, which is a pain in the ass, since the Hercules P32 isn’t supported by Djay Pro.
But can you download and use MIDI Mappings on Djay Pro (Windows edition)?
The downloaded file is from this site
https://support.hercules.com/en/produ…
You can find it under MIDI mapping.
It’s a .zip file. With a .pdf file with instructions and information about the settings.
I’m quoting this.
INSTALLATION:
copy “Hercules P32 DJ.djayMidiMapping” to “~/Library/Containers/com.algoriddim.djay-pro-mac/Data/Library/Application Support/Algoriddim” folder
As you can see by the mac/Data/Library this is for a mac. Not Windows.
Is there a way to still use that MIDI mapping file on Djay Pro Windows 10 edition?
Cause as I mentioned it before. I can’t just follow the instructions on the .pdf file of Hercules, since there is no folder for Djay Pro Windows edition.
