Improve Spotify searching and browsing
I love the Spotify integration in DJay Pro, it’s really a standout feature. I have a few suggestions that would make it even better:
  • Sorting columns in the Spotify search results: when searching in Spotify (so not in a spotify playlist) the results are displayed without an option to sort columns. When searching in a Spotify playlist, you do get the option to sort on columns in the search results. I would love to see the same option in the “search spotify” results.
  • I am a big fan of the “Artist Radio” and “Song Radio” features of Spotify. This gives me a very relevant list of related music. Having this option (maybe as a right click action?) to dynamically create search results in the spotify search inside DJay Pro would be awesome. Same request btw for clicking on an artist name and getting a list of all songs of that artist.
#spotify #search
Thanks for the suggestion @olafmol. I’ll share this with the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
While it also has browsing in the title, I think this is related:
  • In Spotify I organized my playlists in folders. It would be nice if Djay is using the same folders. So you have the same structure as in the Spotify app.
  • If the above functionality is not possible, then I would like the ability to create folders within the Spotify list to organize my playlists. This is less efficient, while I have to manage the folders both on Spotify as in Djay
Thanks for the additional feedback @EwoutdeBoer. I’ll share this with our devs.
My workaround for now: In My collection I created a ‘Spotify‘ folder, with subfolders, which is the same as in Spotify. I dropped all the related playlists in the correct folder.
What I will need to test if this is just a copy from the playlists or some kind of link. What happens when I add or remove tracks in Spotify, will it reflect the playlist in ‘My collection as well‘ I will report back on this
Thanks for sharing your workaround @EwoutdeBoer. Changes that you make to your Spotify playlists outside of djay will not automatically update the playlists you made in My Collection. There is no link.
