After some while using iOS, testing now Windows with Surface/Touchscreen.
Unfortunately the library handling with only touch is limited there. It’s essential to use a mouse or trackpad.
1)Found that it’s not possible to select several tracks and then drag and drop them into Queue or playlists.
In iOS you have this pencil and then you pick songs or even the whole list. Then you can move the selection or remove.
Via Touch on the Surface Pro that‘s not possible.
2)in iOS you have for each title this little circle with the three dots inside, which opens kind of context menu. This allows options as preview, load to deck and add to playlist or queue.
Not in windows via Touch, only when using a mouse.
3)Also the unused streaming Services can’t be hidden.
Hope these functions can be added with the next update.
Best regards
Andy
