on my ipad4, why are my videos & movies seen in djay 2 library? With djay 1, it never did that. It only showed music.
Hi Thierry,
Do you still have djay 1 on your iPad 4? It should show the same content as djay 2 as it’s provided by the system.
There’s currently no way to filter certain files from your library. Also, technically you can play the videos in djay. You’ll only hear the audio part but it works.
This is really irritating, but is maybe mostly an iTunes issue.
Because you have to add movies to iTunes to sync them to the iPad they will show up in recently added, so if you are syncing that playlist you will get the movies in your DJay library as well…
