In djay pro 2 if the reset (eq, effects, controls) check box is unchecked the functions continue to reset after loading tracks.
It still resets for me. How did you reinstall DP2? Do you mean after the update?
Problem is resolved in Version 2.03. Thank you Algoriddim team.
I’m having the same issue. It’s really annoying :(.
Dejay Pro 2 is still a amazing update though!
After reinstalling DP2 everything works again :).
