Feature request for MACOS
not sure if this would be at all possible, given all the processing that is taking place under the hood.
but having choice is always a good thing!
also add the ability for… serial VST3(multi) chains be loaded & and saved as a preset for ease of loading albeit recalling into the FXslot
Thanks for the suggestion @7nz! I have forwarded this to the dev team for consideration.
