mrtime
June 21, 2022, 5:44pm
#1
I just turned on the iPad and the controller (I don’t remember exactly, but it seems like the pitch position on deck 2 was different from 0 when the controller was connected).
https://www.youtube.com/shorts/-g4M5RP_RS4
At the same time, serato plays without issues (same tracks and bpm readings)
https://youtube.com/shorts/vAGdhyKv07E
it is hard to see on the video, but the speed correction in serato and djay (as a percentage) is the same
Which version of Djay are you using?
I’m using 4.0.1 but haven’t updated to 4.0.2
This topic is also in another post that I replied to
This is happening with me too! iPad pro 2020, Rane One, one jog spinning faster than the other, note: does not happen in virtual DJ, usually after a reset it’s fine, but now if I have a gig coming up I have to do a test or check playing two songs at the same time to make sure the jogs are not going wacko, if so I have to restart and check again, usually one time restart does the trick for the rest of the event though, also in most cases the reset only has to be done to the iPad… I’ve been meanin…
Also forgot to mention: I tried switching out different Apple Avi/camera kit adapters and the problem still persist, also if it is a Rane one problem, is there a link for some sort of community forum for Rane? Maybe we can also discuss the problem there, hit it from both ends LOL
