individual mapping for mixon 4 with djay pro on ipad
after using Djay for more then 7 Years I have moved from Mac to iPad using Mixon 4. Using the NS6 with Djay Pro on Mac I configured some buttons to crossfade automatically…
Is it possible to map the functionality of the Mixon 4 individual?
Thanks for your Feedback.
Kind Regards,
Stefan
Dear Dysfunk, thanks a lot for your feedback. I will give it a try!
Hey Stefan,
at the moment we are not supporting a midi learn feature for our iOS applications.
Sorry for that.
Cheers,Lukas E.
Check out DJ Techtools and search for Mixon 4 mappings. There is another software provider iOS who does cater for 4 deck mixing, stems and fully midi mappable using your iPad.
