I’m considering to buy the mentioned hardware. Have a very simple (maybe stupid) question. Once usb cabled to a macbook, can i use the mac core audio as for main output and the headphone output of the mixtour for the prelisten? Or would you suggest to main output directly from mixtour anyway?
You can use the MacBook headphone jack for the main audio OR headphone pre-cue/listen, but personally, I use the Mixtour for both main audio AND headphone pre-cue/listen.
