I bought dj pro in the windows store. Checked the systems requirements before. Unfortunately windows report a unprecedented bug: Code: 0x80240013. No anwer from allgoriddim support for 3 days - only an automatic reply. Basic version with spotify is working.
we are very sorry to hear that.
Could you please delete and redownload djay Pro off the Windows Store and see if the problem is persisting?
Good to hear that, sorry for the djay Pro 2 typo
pro 2 for windows? Did you accidentally announce something?
Same problem, I have a Demo version that works fine and that I want to update so I’ve just bought the app on Win Store but I can’t manage to install it (error Code: 0x80240013).
Hello!!! just purchased software and CANNOT install but all specs seem appropriate
not intentionally, but the uninstall and reinstall worked! thanks
