Device model (e.g. 2020 iPad Air 4th Gen): laptop
Version of operating system (e.g. macOS 14.4.1): windows latest
Version of djay (e.g. 5.1.2): 5.6.9 / 5.6.7040
Hardware/controllers used (e.g. Reloop Mixon 8 Pro): DDJ-FLX10
Hardware firmware version (e.g. 1.0.1): latest 1.14
Please consider sharing a short video or screenshots to help clarify your issue
Instant crash on playback. Regardless of whether a controller is used or not.
load song, press play.
So here’s what’s happened. In the driver utility of the DDJ-FLX10 for windows, I changed the preferences to rekordbox from “other.” The reason, that e.g. virtual dj says not to change from the default mode since otherwise some stuff might not work. I thought, I might try this for djay pro, to see whether anything is different.
Then I started djay pro, immediately after pressing the play button, the app crashes.
I’ve tried to restart the computer a number of times, tried to update everything on the system (was already updated), reinstall the driver from alphatheta, reinstall djay pro, without and with controller being connected and/or switched on or off, USB stick or streaming source – no matter what I do, djay pro crashes immediately after I try to start playback. I have also, of course, tried to switch back from rekordbox to other in the preferences of the utility, but this also makes no difference.
Any idea what I can try to do now? Even after reinstalling djay pro, it’s still not working, so I have no idea anymore what else to try.
Hi @Chris13, to help us troubleshoot your crash, I’ve submitted an Official Support Ticket on your behalf. One of our support team members with contact you shortly via email. As I won’t have access to your crash report, I’ll consider this community topic closed for now and let the official support team take over from here. However, I’ll keep this topic open in case other users experience the same issue. Thanks!
@Chris13, while you wait to hear from the support team, one quick test would help us narrow this down. It crashes with the FLX10 disconnected and with both USB and streaming tracks, so I’d like to rule out the AlphaTheta driver and the audio routing first:
Unplug the FLX10 and uninstall the DDJ-FLX10 driver (the Setting Utility comes with it) from Windows.
Restart your laptop.
Open djay and go to Settings > Audio devices. Set Mixer mode to Internal and Main Output to your laptop’s built-in speakers.
Load a local file and press play.
If it plays normally, the driver is the most likely cause, and you can reinstall a fresh copy from AlphaTheta and leave the utility on its default setting. If it still crashes, post back here and add that to your support ticket too. Either way, it tells the team whether the controller side is involved. Thanks!
With the help of AI I got the app to work again, mostly anyway … have to still test in detail. Here’s the summary:
Resolved. The crash was not caused by the DDJ-FLX10 driver or the Setting Utility mode.
Crash signature (Event Viewer):
Faulting application: djayApp.exe 5.6.9.0
Faulting module: objc.dll — inside djay’s own package (C:\Program Files\WindowsApps\59BEBC1A.djay_…\objc.dll)
Exception: 0xc0000005, offset 0x120fd
Hashed bucket 7e7e3a1da2e8cc8525cf3c5e08278b10, identical on every occurrence → single deterministic code path
Root cause: a corrupt MediaLibrary.db.
My Music\djay folder was being synced by Proton Drive. The folder contained sync-generated conflict copies of SQLite’s live companion files — MediaLibrary (# Edit conflict <date> <deviceID> #).db-wal and .db-shm — dated 15 Aug, 24 Aug, 1 Sep, 2 Sep and 11 Oct. djay had already self-quarantined a damaged library twice: djay Media Library (Corrupt 2026-08-24 16-05-20) and MediaLibrary-damaged.db (3 Sep). A sync client cannot safely replicate an open SQLite database; the .db, -wal and -shm files must stay mutually consistent.
Reverting the FLX10 Setting Utility from “rekordbox” back to “other”
Deleting com.algoriddim.djay-windows.plist — app came up fully reset but still crashed, though it then played ~1 second of audio before dying and stopped producing an Event 1000, self-terminating instead
What fixed it: renaming Music\djay aside. djay played immediately with an empty library. I then restored MediaLibrary.db from djay’s own dated backup (Backups\2026-10-11, written 11:11, before that day’s 12:23 sync conflict). Playback works and all cue points and playlists are intact.
Prevention:Music\djay excluded from Proton Drive permanently.
Two notes for the team:
djay hard-crashes on a damaged library rather than failing gracefully — a readable error would have saved hours.
djayApp writes its own entries to the Windows Application log, but with Event ID 0 and an empty message string, so they’re unreadable to users. If those carry diagnostic text, exposing it would be very useful.
Hi again @Chris13, nice work! Your fix matches our official restore process. djay makes a backup of the Media Library each day you launch it and keeps up to 10 of them in %HOMEPATH%\Music\djay\Backups. Restoring one from before the corruption was the right move. Keeping Music\djay out of Proton Drive is a smart call as well.
One favour: could you reply to your support ticket email and attach the damaged files? That means the “Corrupt” folder, MediaLibrary-damaged.db, and the conflict copies, plus your Event Viewer details. The team uses corrupted databases to improve djay’s stability. Please also let me know how the detailed testing goes. Thanks!
