I’m using a RANE ONE with latest version DJAY in 4 deck mode. For the life of me i can’t figure out how to swich a song from deck 2 to deck 4 using instant double. The program sends deck 1 over instead. Is there a way to force the program to instant double from the deck you choose (hope that makes sense). If i’m playing on deck 1&2 at the same time, I would like for deck 1 to always instant double to deck 3, and deck 2 to always instant double to deck 4. Is this possible?
It probably is but it would probably need an edit to the midi mapping to do it,
Maybe Shift + load
Hi @DJ_A_Diffrance,
Instant double currently always doubles the active deck (e.g., deck 2 if the crossfader is all the way to the right) to decks 3 and 4.
However, your POV makes sense for potentially updating this default behavior.
We’ve gone ahead and shared this with our engineering team as a feature request for further consideration.
Additionally, I will be moving this topic to the Suggestions category of the community so that others may vote on this as a request.
Thanks. That would be great if they implement that. Much appreciated.
