Is there anything that can be done to improve the look of the FX screen. For example Dub Echo is shown as Dub Ec…Instead of 3 dots surely you can put the last 2 letters.
Is this an algoriddim thing or sn Apple thing, in which case could use you contacts to improve this.
As you can see, 4 out of the 8 FX’s have this issue. All 4 could be resolved by utilising the space underneath.
Instead of
Echo O…. You would have
Echo
Out+
Seems a simple solution.
