I use the Rane One. Is there a way to map a button that that will instantly switch a decl to accapela while also switching the other deck to instrumental or the other way around? I hope this makes sense. Thanks in adance.
@SamJam this should be possible. Essentially you need to:
- Map a free button on the Deck 1 side of your controller to Target: Deck 1 and Action: Neural Mix Solo (2ch: Acapella)
- Use the Duplicate function by siding left on the MIDI command you just made.
- Select this new empty MIDI command right below the one you just mapped.
- Now map this to Target: Deck 2 and Action: Neural Mix Solo (2ch: Instrumental)
Now when you press that button Deck 1 with switch to Acapella and Deck 2 will switch to Instrumental.
You’ll want to repeat this process with a second button on the Deck 2 side so you have the choice of Deck 1 or Deck 2 being the Acapella side.
Excellent I will try this. Thankyou.
I cant dind the duplicate option on my Macbook
Sold my MacBook so I can’t help you there. I’m sure it’s available via a r-click or something like that.
Yes thats it thanks.
