Intelligent HOT CUE points
Dear,
Because you don’t always mix a song the same way depending on the previous track, it would be amazing to have intelligent HOT CUE points or to be able to save different sets of 8 HOT CUE points and access them through a dropdown menu.
I have this hit banger song “A” that I mix at the moment of the drop if the previous track is “B”.
But if previous tune is “C”, then I introduce song “A” with an a cappella over the bridge of “C”.
The same goes for the next mix, my HOT CUE points for A change whether I mix with song “D” or “E”.
These 2 different configurations require a different set of HOT CUE points.
It would be great that either the system adapts automatically the 8 HOT CUE points based on the song loaded on the decks or, even better, that I could select with a dropdown menu my 8 pre-saved HOT CUE points with a custom name.
Thank you,
Nicolas.
Thanks for the suggestion @Nicolas. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left so we can gauge user demand for this idea.
