Here’s my first question.
For a week now I have been experimenting with Djay Pro 5.0. I own a Numark NS6II and I have some issues. In this topic I wil talk about one of my issues, I will open another topic for other issues.
Yesterday I wanted to record a mix. Audio limiter and Auto gain are both on, output headroom is at -6 dB.
The gain knob are at 12 o’ clock and because of auto gain, they should be allright. I noticed when loading a new track an I pre-listened the audio was way to loud. When moving the gain knob a little and set it back to 12 o’ clock the gain was ok.
I found this very annoying.
I als noticed that the auto gain was not flawless. When checking the recording I noticed the main volume of the tracks was not equal at all.
Today I did a test with recording from the booth output of my NS6II. The problem with the gain when loading a song was gone now. So the gain issue must be an internal recording problem.
When recording outside Djay the auto gain issue remained the same as before.
I don’t know if this is because the combination with Djay and NS6II or that it is a bug.
I come from Serato and the auto gain there is not always right but I think it is slightly better than Djay.
I just did a test and this time the gain stayed OK.
The problem I described was my first attempt for a recording inside Djay. I did a mix with 15 tracks and all tracks had to be adjusted because the gain was way to loud.
Just now it was fine.
I’m sorry but I did not manage te recreate this.
Just for the record.
Djay Pro 5.0.3
Macbook pro 2020 13 inch i5
Mac os Sonoma 14.1.2
