Jonnyuk
              1
              Still having issues after update with iTunes is there a fix as I’m performing tonight?
Jon Uk
Summary of the issue:
How to reproduce the issue:
              If the error is coming from iTunes servers, then the problem needs to be fixed by Apple.
"The 500 Internal Server Error is a generic error code that means the server had an unexpected problem and could not fulfill the request. "
There’s not much you can do.
Like fully reboot your device
or  use apple time machine to revert iTunes to previous version.
If you have VPN turned on, check the connection without VPN.
              Hi @Jonnyuk,
Thanks for sharing your issue in the community.
Just checking in to see whether or not @dj_romy_fi’s guidance resolved your issue?
Thank you, @dj_romy_fi, for the assistance.
Have a nice day, all!
