Invalid certificate error on iPad
Good day
I am new to DJay and I became interested as I am responsible for the music at a huge family party for New Year.
I installed the app on my iPhone and it works great. I M in the trial for the pro version. I thought it would be great to use it in my large iPad Pro 2nd gen.
I installed version 5.2.6 and it ran great, until my iPad told me to load the latest iOS 17.7.3
After the install, DJay does not work. When staring, it says:
“ The certificate for this server is invalid. You might be connecting to a server that is pretending to be api.revenuecat.com which could put your confidential information at risk.”
I have reset my iPad, deleted Djay and re-installed it. Still the same. If I click OK, it does not allow me to load Apple Music. It gives me a similar error message.
The software is unusable on my iPad for some reason.
Any suggestions? I would really appreciate the help.
Thank you
Hi @Rescue78, welcome to the community. Can you please verify that the date and time is set correctly on your iPad?
I did verify that and the date and time are correct.
Thanks. Could you please try going to https://www.revenuecat.com in Safari on your iPad and see if that works?
Also, if you’re using a VPN please try disabling it.
No VPN.
Interesting though. When I try to go to api.revenuecat.com on Safari, it gives me a “This connection is not private” error and has a similar message saying that this website may be impersonating revenuecat.com
Thanks for your help. I am all good now. There was an old app on my phone that prevented access to Revenuecat.
Thank you for your time and willingness to help.
Happy Holidays
Thanks for the follow up @Rescue78. Glad you got it sorted out.
