Ion DJ 2 Go / ipad not supported anymore ?
Hello,
I purchased Djay 2 specificatly because it is advertised as compatible with ion DJ 2 Go. I have an Ipad Pro (iOs 10.3.3) and the app keeps stating that the app is not compatible with the Ion Dj 2 go.
Could you please advise ?
Regards,
Alex
I have the same issue.
The algoriddim website stated that the ION DJ2Go is supported, but when i connect the ION DJ2Go to the iPad using the camera connection kit, it gives an error that the device is not compatible…
Is there any fix to this???
