Please help. I have the ion dj2go controller - the exact one you show on your website as being compatible with day 2. When I try to use It with day2 I get a message saying the hardware is not supported by djay.
The controller works with other software. Please help.
I’m running an I pad air on the newest OS.
Thanks.
I am wondering about this aswell since I want a small controller for the IPAD and djay app.
But I found it hard to get hold of the controller so maybe it has stopped selling.
Are there any alterantives for dj:ing on ipad with a small external controller?
Hello again. I have used midi wrench and can see the controller active within this app. The ion works with all other dj apps on my I pad but not djay? I am about to upgrade to a different controller but I’m not sure if I should at this stage. It’s a bit confusing to have you guys endorse the ion as being compatible when mine doesn’t work. I am fearful this will also happen with my next controller.
iPad Air 2 (128 GB)
iOn DJ2Go
iOS 9.1 (13B143) (not updated yet on purpose)
The “class compliant” controller does not work with Djay PRO on iPad.
I even tried to connect the controller with the Apple Lightning to 30-pin Cable and the Native Instruments 30-pin to Mini-USB Cable. But that doesn’t help.
Then i tried it with the new Apple Lightning to USB 3 Cable INCLUDING connecting it to a self-powered USB-hub. But this doesn’t work either.
