I noticed that the only time you can use the jog wheel to scratch or backspin is when DJAY play mode is off. Meaning the record isn’t spinning. If this feature was enabled then this little djay controller would be so powerful. Just a thought =)
Thanks for the latest update… Can’t wait to try it!
have you figured it out? same question here
