My djay app no longer works on iPad as it states it has to be ios11+ my ipad can only go Los 9
Hi Andrew,
Thank you for your message.
Which djay app did you use formerly?
Cheers,Lukas E.
Hi well I bought the numark set up which slots the iPad into it and had deejay 2 but they must of updated it now is there any other apps to use this on?
