Hello,
I’m curious about updating my ipad into latest version which is iOs 6.1, will it work with my idj pro if I upgrade my iPad?
Thanks,
Team’Bre3zy
Hello,
Thanks,
Team’Bre3zy
Yes, iDJ Pro is compatible with iOS 6.0.1.
Are u sure about that? The last time I upgraded my ipad my idj live got screwed and I had to buy this idj pro which is doing great so far… Just need to get use to it I guess…
Thanks,
Bre3z
As of right now, the only thing that won’t work is full multi-channel stereo. Everything else seems to work fine. Unless of course you’ve got an iDJ Pro with the correct firmware from Numark.
