IOS 9 & Djay 2 For Ipad
Record is now Skipping and Freezing momentarily when pressing the + sign on opposite Turntable and Freezing momentarily when mixing…Please Investigate
Problems with Djay in iOS 9? Is thuis gonna be fixed?
I got tracks skipping/pausing on iPad 32gb with idjpro and latest iOS 10/15/15. On regular play. Spotify and purchased iTunes music.
We’ve been waiting for over a month. Apparently they are aware of the problem. I wouldn’t expect any update until the release of Djay Pro for iPad Pro unfortunately. :confused:
same here. I hope you fix this with an update.
ipad3 wifi/gsm 32gb, ios9, djay2, itunes
@Adrian: any comments from Algoriddim please???
So that doesn’t happen when not recording your mix? Which iPad model do you use?
Hey Adrian. Sorry for the delay…I have an Ipad 3 Wi-fi + 4g And my Co-worker has an Ipad Air Model #MF009LL/A…They both are doing the same thing since we went to IOS 9
please note that the thread is 7 moths old.
Regarding your issue, could you please send us a video of the explained behaviour via support@algoriddim.com?
That would help us tons in order to reproduce your issue.
I am having issues to with IDJ locking up and being real slow after i upgraded to IOS9 when will a fix be ready for this
Algoriddim… no response… is this getting sorted?
Is there anybody there???
Adrian… is there a fix for the ios 9 issues with djpro for ipad
Argh. I just stumbled into that painful performance lag too, after updating my iPad3 Wifi/GSM 32 GB up to iOS9 :frowning:
While playing on the one deck and searching through my library I sometimes get a small lag of the playing deck.
Also syncing or adjusting the BPM for a song creates permanent lags of the deck which isn’t playing the original tempo.
Please fix it soon.
PS: With iOS8 it worked fine.
problem with a big Lag of the playing deck when i charge any song by my music o Spotify. Please Update!!!
Never Mind. I switched to Setato And that solved the problem just fine.
