iOS compatible DVS Interfaces
Currently on the market, as far as I can tell:
  • Pioneer DJ Interface 2
  • Denon DJ DVS Iterface
  • Reloop Flux.
Which ones are compatible with my 2 year old iPad (USB-C connector) and djay?
Thanks in advance.
I don’t have experience with any of these audio interfaces, but if I had to choose one to gamble on, it would be the Reloop Flux. Not only is it the newest, class-compliant and USB-C powered, but Reloop also has a close relationship with Algoriddim so I’d bet on it working over the other options.
I think your answer makes a lot of sense.
Thank you for taking the time to answer.
You’re welcome. Maybe you can get one on Amazon or somewhere else with a good return policy so you can send it back if it does t work.
