iOS compatible interfaces for pre-cue
Is there a longer list of devices that can be used to pre-cue listen for iOS (if it worked for Mac as well that would be even better). I know the Traktor Kontrol Z1 can be used for pre-cue, but is not midi mapped to control djay. Maybe something in the $100 range? Native iOS support (I occasionally use an iPhone so the CCK isn’t useful to me) would be best.
Supposedly with iOS 7, the CCK is supposed to work with the iphone according to various people who used the Beta, of course I’d wait till next week to take that as gospel.
That would be phenomenal if it’s true. Hopefully it would still work with the 4s. In the meantime, are there any class-compliant audio interfaces that people have used with the iPad for cueing and can recommend?
