Unable to send audio only to Airplay devices via iOS DJ Pro app on iphone. Only options are Airplay mirroring to Apple TVs on network. How do you disable video output to allow Airplay to audio only devices?
Hi Joe,
thank you for your post. In the drag up Airplay options of your iPhone, are the mirror device screen options enabled?
Hi Joe,
that sounds odd. I found this Airplay troubleshooting guide in the internet:
http://www.appletvhacks.net/2015/04/01/cannot-airplay-mirror-iphone-ipad-apple-tv-troubleshoot/
See if it is helping, also keeping your device updated is always a good thing to do.
While I’m not on my home network, Airplay mirroring option is available and it’s not selected.
When I’m on my home network, where I want to use Djay Pro, no Airplay options are available.
