Hi guys. I have the Ipad Pro 2018, the DDJ-200 and djay pro 2 installed. As you probably know the DDJ-200 connects to the ipad with bluetooth, which means audio and cueing need to be split from the Ipad.
Only thing is the ipad only has a single USB-C port, which also needs to be used for charging.
SO to combat this I brought a USB-c to USB-c/minijack adapter. From the adapter I run the minijack splitter to allow me to split the mono into audio and cueing.
The problem is the feed isnt splitting, so I have no cueing. Any Ideas?
